Ir para o conteúdo principal
A Jammed SD Card Tray
O que você precisa
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, imagem 1 %32 A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, imagem 2 %32
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: passo 2, imagem 1 %32 A Jammed SD Card Tray, Popping up tray: passo 2, imagem 2 %32
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: passo 3, imagem 1 %32 A Jammed SD Card Tray, Popping open tray: passo 3, imagem 2 %32 A Jammed SD Card Tray, Popping open tray: passo 3, imagem 3 %32
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: passo 4, imagem 1 %32 A Jammed SD Card Tray, Remove sd card: passo 4, imagem 2 %32 A Jammed SD Card Tray, Remove sd card: passo 4, imagem 3 %32
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
Conclusão
Thanks and you’re welcome now you have free access to your sd card!
Uma outra pessoa concluiu este guia.
Sqwerks
Membro desde: 10/31/22
563 Reputação
Autoria de 1 guia
Equipe
The Sqwerks repair team Membro de The Sqwerks repair team
Community
1 Membro
Autoria de 2 guias
4Comentários do guia
My first guide 😂
Sqwerks - Responder
its been officially accepted as of two months ago yahoo
Sqwerks - Responder
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - Responder
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 59
Ao todo: 1,452
