Ir para o conteúdo principal
8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement
O que você precisa
  1. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement, Battery: passo 1, imagem 1 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement, Battery: passo 1, imagem 2 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the four screws from the back cover of the controller using a T6 Torx screwdriver.
  2. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 2, imagem 1 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 2, imagem 2 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 2, imagem 3 %32
    • Insert a Jimmy into the crevice of one of the controller's bottom grips and use it to follow the lining of the crevice around the whole controller.
    • Opting for a plastic wedge instead of other metal tools may be a more practical choice. Metal tools may bend and cause cosmetic damage.
  3. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 3, imagem 1 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 3, imagem 2 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 3, imagem 3 %32
    • Gently separate the front and back casing of the controller to expose the battery.
  4. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 4, imagem 1 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 4, imagem 2 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 4, imagem 3 %32
    • Gently grab the white plastic front of the wire that is connected to the motherboard to detach it from its plug.
    • Be sure to only unplug the wire that connects the battery to the motherboard. No other wire needs to be unplugged for this specific replacement.
  5. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 5, imagem 1 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 5, imagem 2 %32 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 5, imagem 3 %32
    • Remove the battery from its position.
    • There will be adhesive at the back of the battery that may raise concern. However, removing the battery will not damage it or the controller.
  6. 8bitDo Ultimate C 2.4g Wireless Controller Battery Replacement: passo 6, imagem 1 %32
    • Apply the iFixit stretch release adhesive to the back of the replacement battery and place the new battery in the same spot as the old one.
    • Make sure to plug in the new battery's wire into the controller's motherboard.
Conclusão
letarian
Membro desde: 02/21/24
190 Reputação
Autoria de 1 guia
Equipe
2 comentários
Where did you boght the battery replacement? I'm trying to find it on the internet but no clues yet
Lucas Simões - Responder
Hi, where can I get the new battery for replacement?
Juan Manuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 73
Últimos 30 dias: 346
Duração total: 644
