Introdução
You can access the vibration/rumble motors with this guide if they need to be replaced. You may need to replace the weights if they aren't activating when they need to or continuously running. For this guide, you will need a plastic opening tool, a Phillips #0 screwdriver head, a TR6 Torx Security Screwdriver, and ESD Safe Blunt Nose Tweezers (optional). You will not need to do any difficult steps, but be careful when opening the top panel. Ensure the controller is not plugged into a power source or operating system.
O que você precisa
Orient the controller such that the back of the controller is facing you.
Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
