Introdução
If you need to replace the buttons, you can access them with this guide. You may need to change the buttons if they are worn down, cracked, jammed, or missing. For this guide, you will need a plastic opening tool, Phillips #0 screwdriver, TR6 Torx Security screwdriver, and ESD-safe blunt nose tweezers (optional).
This repair process is not too difficult, but be careful to not damage anything when you take off the top panel. Make sure the controller is not plugged into a power source.
O que você precisa
Orient the controller such that the back of the controller is facing you.
Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
8 outras pessoas executaram este guia.
2Comentários do guia
I purchased mine from the official store: https://shop.8bitdo.com/collections/repa...
Zarlin -
