Ir para o conteúdo principal
8BitDo SN30 Pro+ Controller Rumble Motors Replacement
O que você precisa
  1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: passo 1, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: passo 1, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: passo 1, imagem 3 %32
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: passo 2, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: passo 2, imagem 2 %32
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: passo 3, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: passo 4, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: passo 4, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: passo 4, imagem 3 %32
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Covers: passo 5, imagem 1 %32
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: passo 6, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: passo 6, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: passo 6, imagem 3 %32
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: passo 7, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: passo 7, imagem 2 %32
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: passo 8, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: passo 8, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: passo 8, imagem 3 %32
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: passo 9, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: passo 9, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: passo 9, imagem 3 %32
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
  10. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: passo 10, imagem 1 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: passo 10, imagem 2 %32 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: passo 10, imagem 3 %32
    • Flip over the rear board
    • Using a soldering iron to desolder the rumble motor wires.
    • During reassembly, remember to solder the wires back into the same position.
Conclusão
Uma outra pessoa concluiu este guia.
Brian W
Membro desde: 12/21/11
1.773 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 766
