Introdução
Use this guide to replace the battery on the 4Sight 9
O que você precisa
Place the tablet on its side so that the two screws are facing upward.
Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
7 outras pessoas executaram este guia.
