Ir para o conteúdo principal
42" LG TV LED Strip Replacement Tutorial
Vídeo de Apresentação
  1. 42" LG TV LED Strip Replacement Tutorial, LED Strip Replacement Tutorial: passo 1, imagem 1 %32
    • Remove the screws from the rear of the television, as well as the back cover.
    Pergunte ao FixBot
  2. 42" LG TV LED Strip Replacement Tutorial: passo 2, imagem 1 %32
    • Remove the screws that connect the IR sensor to the mainboard to remove and detach it.
    Pergunte ao FixBot
  3. 42" LG TV LED Strip Replacement Tutorial: passo 3, imagem 1 %32
    • Disconnect the ribbon wires from the buffer boards using the provided connectors.
    Pergunte ao FixBot
  4. 42" LG TV LED Strip Replacement Tutorial: passo 4, imagem 1 %32
    • Remove the speakers from the mainboard by disconnecting them from it.
    Pergunte ao FixBot
  5. 42" LG TV LED Strip Replacement Tutorial: passo 5, imagem 1 %32
    • Remove the screws on the assembly that are around the television.
    Pergunte ao FixBot
  6. 42" LG TV LED Strip Replacement Tutorial: passo 6, imagem 1 %32
    • Remove the screws that hold the buffer board in place.
    Pergunte ao FixBot
  7. 42" LG TV LED Strip Replacement Tutorial: passo 7, imagem 1 %32
    • For certain covers, you may need to pry the clips away from the bezel using a five-in-one tool or something similar to free the clips.
    Pergunte ao FixBot
  8. 42" LG TV LED Strip Replacement Tutorial: passo 8, imagem 1 %32
    • Remove the buffer board covers from the board.
    Pergunte ao FixBot
  9. 42" LG TV LED Strip Replacement Tutorial: passo 9, imagem 1 %32
    • To get the buffer boards free, release the tabs on the boards.
    Pergunte ao FixBot
  10. 42" LG TV LED Strip Replacement Tutorial: passo 10, imagem 1 %32
    • Remove the bezel by flipping the television over.
    Pergunte ao FixBot
  11. 42" LG TV LED Strip Replacement Tutorial: passo 11, imagem 1 %32
    • Flip up the buffer boards and tape them to the panel using suction cups.
    Pergunte ao FixBot
  12. 42" LG TV LED Strip Replacement Tutorial: passo 12, imagem 1 %32
    • Remove the panel off the television by lifting it evenly so that it does not break.
    Pergunte ao FixBot
  13. 42" LG TV LED Strip Replacement Tutorial: passo 13, imagem 1 %32
    • Remove the panel frame.
    Pergunte ao FixBot
  14. 42" LG TV LED Strip Replacement Tutorial: passo 14, imagem 1 %32
    • Tape the diffusion layers together at the corner to keep them aligned, then remove the layers of diffusion one by one, starting at the corner.
    Pergunte ao FixBot
  15. 42" LG TV LED Strip Replacement Tutorial: passo 15, imagem 1 %32
    • The reflector is held in place by two sets of tabs located on each side of it.
    Pergunte ao FixBot
  16. 42" LG TV LED Strip Replacement Tutorial: passo 16, imagem 1 %32
    • Pinch the smaller tabs through the chassis on the board side, using needle-nose pliers to get them tight.
    Pergunte ao FixBot
  17. 42" LG TV LED Strip Replacement Tutorial: passo 17, imagem 1 %32
    • Some of the smaller tabs may be placed under the boards; to reach at least one of the smaller tabs, you will need to remove the t-con board.
    Pergunte ao FixBot
  18. 42" LG TV LED Strip Replacement Tutorial: passo 18, imagem 1 %32
    • To release the bigger tabs, you will need to raise one side while sliding it.
    Pergunte ao FixBot
  19. 42" LG TV LED Strip Replacement Tutorial: passo 19, imagem 1 %32
    • Remove the reflector sheet.
    Pergunte ao FixBot
  20. 42" LG TV LED Strip Replacement Tutorial: passo 20, imagem 1 %32
    • Use a five-in-one tool or something similar to disconnect the LED strips from the power cables and pry underneath the LED strips to lift them out of their mounting brackets on the chassis.
    Pergunte ao FixBot
  21. 42" LG TV LED Strip Replacement Tutorial: passo 21, imagem 1 %32
    • Connect the new LED strips and make sure they are properly aligned on the chassis.
    Pergunte ao FixBot
  22. 42" LG TV LED Strip Replacement Tutorial: passo 22, imagem 1 %32
    • Reconnect the LED strips to the power cable as they have been disconnected.
    Pergunte ao FixBot
  23. 42" LG TV LED Strip Replacement Tutorial: passo 23, imagem 1 %32
    • Reconnect the reflector sheet and clips to the reflector frame.
    Pergunte ao FixBot
  24. 42" LG TV LED Strip Replacement Tutorial: passo 24, imagem 1 %32
    • Remove the tape from the layers of diffusion and reinstall them.
    Pergunte ao FixBot
  25. 42" LG TV LED Strip Replacement Tutorial: passo 25, imagem 1 %32
    • Reinstall the panel frame.
    Pergunte ao FixBot
  26. 42" LG TV LED Strip Replacement Tutorial: passo 26, imagem 1 %32
    • Adjust the panel's position and then remove the suction cups.
    Pergunte ao FixBot
  27. 42" LG TV LED Strip Replacement Tutorial: passo 27, imagem 1 %32
    • Release the buffer boards from the tape.
    Pergunte ao FixBot
  28. 42" LG TV LED Strip Replacement Tutorial: passo 28, imagem 1 %32
    • Reinstall the bezel and tighten it down using the screws that run around the perimeter of the TV.
    Pergunte ao FixBot
  29. 42" LG TV LED Strip Replacement Tutorial: passo 29, imagem 1 %32
    • Reinstall the buffer board covers on the board.
    Pergunte ao FixBot
  30. 42" LG TV LED Strip Replacement Tutorial: passo 30, imagem 1 %32
    • Reconnect the t-con board and ribbon wires as they are disconnected.
    Pergunte ao FixBot
  31. 42" LG TV LED Strip Replacement Tutorial: passo 31, imagem 1 %32
    • Reinstall the speakers and connect the wire to the mainboard.
    Pergunte ao FixBot
  32. 42" LG TV LED Strip Replacement Tutorial: passo 32, imagem 1 %32
    • Reinstall the infrared sensor and tighten it to the chassis once more.
    Pergunte ao FixBot
  33. 42" LG TV LED Strip Replacement Tutorial: passo 33, imagem 1 %32
    • Reinstall the back cover and put the screws back in place.
    Pergunte ao FixBot
Conclusão
Removing and Reinstalling 4G LG TV LED Strips may sound tricky or complicated; however, after reading this tutorial for replacing the LED strips of LG 42inch LED TV, you can do it by yourself now! I hope you enjoy it. See you in the next tutorial.
21 outras pessoas executaram este guia.
Rachel Burnham
Membro desde: 07/16/21
1.101 Reputação
Autoria de 1 guia
5Comentários do guia
Tv Lg 42lv3500 no se ve imagen , lo único que se ve son líneas de color verticales y luego van desapareciendo hasta quedar en negro , me podrían ayudar por favor
carlos fagundez - Responder Compartilhar
No one ever shows how to get the wire adapters off the ends of the LED strips! Also, the spacers are very brittle, if you put a 5 in one under it, it will break. Take them off from behind and just push it in a little where the catch is and slide it gently on the face side.
Kevin York - Responder Compartilhar
My Tv is blank (not showing picture but has a black light display instead of pictures) but still plays sound loud and clear. What could be the problem please? “LG 43" smart. Model 43uk6400plf. Firmware 5.50.15”
AfolabI Olakanmi - Responder Compartilhar
Mine has the similar situation, no picture shown most the time and whenever picture is on, left half of the screen is flickering with white stripes (on and off) , I thought it might be the display controller's problem but not sure, will someone could guide a direction on how to fix it?
Sherman
Sherman Hsu - Responder Compartilhar
Hola, mi televisor LG lo apretaron mucho y malogrado la pantalla de tal manera q ahora solo se ven unas línea de colores, no se ve imagen
Janet - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 49
Últimos 7 dias: 325
Últimos 30 dias: 1,717
Ao todo: 81,275
