Ir para o conteúdo principal
4-Stroke Small Gas Engine Spark Plug Replacement
O que você precisa
  1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, imagem 1 %32 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, imagem 2 %32 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, imagem 3 %32
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. 4-Stroke Small Gas Engine Spark Plug Replacement: passo 2, imagem 1 %32 4-Stroke Small Gas Engine Spark Plug Replacement: passo 2, imagem 2 %32
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  3. 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, imagem 1 %32 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, imagem 2 %32 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, imagem 3 %32
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
Conclusão
Jack Linchey
Membro desde: 04/19/18
277 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 1,562
