Pular para o conteúdo principal
Introdução
In a gasoline engine, a Spark Plug provides an electrical spark to ignite to fuel inside, generating horsepower. Over time, a Spark Plug's ability to ignite will reduce from wear and eventually not work. Replacing Spark Plugs ensures your engine will run at optimal efficiency.
  1. Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it. Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it. Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Make sure the engine is turned off and cool to the touch before completing this step. Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  4. Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise. Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet. Remove the Champion RC12YC Spark Plug from the device.
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Jack Linchey
Membro desde: 19-04-2018
253 reputação
2 Guias de autoria
Equipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membros
7 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Todo: 87
