Ir para o conteúdo principal
4-Stroke Small Gas Engine Air Filter Replacement
O que você precisa
  1. 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, imagem 1 %32 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, imagem 2 %32 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, imagem 3 %32
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. 4-Stroke Small Gas Engine Air Filter Replacement: passo 2, imagem 1 %32
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
Conclusão
Ethan Narad
Membro desde: 04/19/18
529 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 643
