Introdução
The propeller motors are a crucial component in providing power to the propellers so that the 3DR Iris Plus can fly. However, if you are experiencing any problems with one or more motors that is preventing the drone from flying (which can be diagnosed using our troubleshooting guide), you will need to replace them. This guide details how to replace one of the motor assemblies used within the 3DR Iris Plus.
O que você precisa
Power off the drone by holding down the power button.
Remove the battery by disconnecting it from the main battery connector.
Press the power button again to ensure all electricity is discharged.
Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
This is the motor assembly.
If your drone is equipped with it, remove the video transmitter.
Disconnect all cables from the gimbal.
If your drone has neither the gimbal or video transmitter, you can skip this step.
Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
Ensure that the drone is in the same orientation as the picture (power connector and capacitors on the bottom).
Top-left motor power cables
Top-right motor power cables
Bottom-left motor power cables
Bottom-right motor power cables
Desolder the motor power cables closest to the motor that you are replacing (the cables in each corner route to the closest leg).
Remove each of the plastic clips holding the motor cables in by snapping them out.
Remove the two 9mm screws using a 2 mm Hex screwdriver/key. Once removed, the motor will hang freely from the leg chassis.
Remove the LED assembly by snapping it off the clips that are attached to the drone leg.
Um comentário
Thanks for the info Duncan , I am finding it difficult to simply snap off the led clip away from the arm is there a secret? Lol!
