Introdução
The gimbal allows for the rotation of an object such as a camera. If your gimbal is experiencing malfunctions such as gimbal overload, lack of rotation, abnormal vibrations, etc., follow this guide to remove the gimbal and replace the part.
O que você precisa
If your drone is equipped with it, remove the video transmitter.
Disconnect all cables from the gimbal.
If your drone has neither the gimbal or video transmitter, you can skip this step.
Uma outra pessoa concluiu este guia.
Um comentário
Where are the two wires connect to the gimbal one is a ground and the white wire connects to the power, but where?
