Ir para o conteúdo principal
3DO FZ-1 Disassembly Guide
O que você precisa
  1. 3DO FZ-1 Disassembly Guide, Lets Begin!: passo 1, imagem 1 %32 3DO FZ-1 Disassembly Guide, Lets Begin!: passo 1, imagem 2 %32 3DO FZ-1 Disassembly Guide, Lets Begin!: passo 1, imagem 3 %32
    • Here we have the front view of the FZ-1 3DO.
    • Note the ports on the back of the unit. The FZ-1 comes with RF, S-Video, and Composite Outputs, as well as a expansion port on the back of the unit.
    • A larger 2nd expansion slot can be found on the right side of the unit.
  2. 3DO FZ-1 Disassembly Guide, Outer Casing: passo 2, imagem 1 %32
    • Flip the unit over, so that the bottom side of the case is facing up towards you, exposing the four screws casing screws.
    • Remove the four #2 Phillips Screws from the casing.
    • After the screws are removed, flip the unit back over while holding the top and bottom pieces of the case together.
  3. 3DO FZ-1 Disassembly Guide, Top Casing: passo 3, imagem 1 %32
    • Remove the top portion of the case to expose the internal components.
  4. 3DO FZ-1 Disassembly Guide, Disc Drive: passo 4, imagem 1 %32 3DO FZ-1 Disassembly Guide, Disc Drive: passo 4, imagem 2 %32 3DO FZ-1 Disassembly Guide, Disc Drive: passo 4, imagem 3 %32
    • Remove the 2 #1 Phillips Screws from the back of the Disc Drive Shield.
    • Using a Spudger, carefully pry up the four metal tabs to remove the disc drive cover.
    • Remove the 4 #2 Phillips Screws.
    • Remove the disc drive shield, and the two bars you just unscrewed.
  5. 3DO FZ-1 Disassembly Guide: passo 5, imagem 1 %32
    • Remove the 5 #1 Phillips Screws holding the CD Drive to the motherboard.
    • Carefully unplug the two ribbon cables connecting the CD drive to the motherboard.
    • You can now safely remove the CD drive from the case.
  6. 3DO FZ-1 Disassembly Guide: passo 6, imagem 1 %32 3DO FZ-1 Disassembly Guide: passo 6, imagem 2 %32
    • Remove the 11 #1 Phillips Screws connecting the metal shield to the motherboard.
    • Remove the metal shield.
    • Remove the metal cover from the expansion port.
  7. 3DO FZ-1 Disassembly Guide: passo 7, imagem 1 %32
    • Remove the #1 Phillips Screw from back port cover, and then remove the cover.
  8. 3DO FZ-1 Disassembly Guide: passo 8, imagem 1 %32 3DO FZ-1 Disassembly Guide: passo 8, imagem 2 %32
    • Remove the plastic cover, power and eject buttons found at the front end of the unit.
  9. 3DO FZ-1 Disassembly Guide: passo 9, imagem 1 %32 3DO FZ-1 Disassembly Guide: passo 9, imagem 2 %32
    • Unplug the power and fan cables from the motherboard.
    • Remove the 2 #2 Phillips Screws holding the power supply to the case.
    • The electric screwdriver comes in handy loosening the PSU screws on the FZ-1.
    • Remove the power supply and fan from the case.
  10. 3DO FZ-1 Disassembly Guide: passo 10, imagem 1 %32
    • Unplug the ribbon cable connecting the motherboard to the controller port board.
    • Remove the controller board and motherboard.
    • Remove the metal shield at the bottom of the case. Mission complete!
Conclusão
8 outras pessoas executaram este guia.
Ben Eccles
Membro desde: 02/06/16
933 Reputação
Autoria de 1 guia
2Comentários do guia
Can you tell me what size the screws are? I need to order a replacement set for my FZ-1
Richard Poll - Responder
I thought I couldn't fix this old appliance in my house. Until I came across this site! Thank you. :)
Jellyna Studio - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 99
Ao todo: 8,414
