Ir para o conteúdo principal
360fly 4K Lens Replacement
O que você precisa
  1. 360fly 4K Lens Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Lens Replacement: passo 2, imagem 1 %32
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K Lens Replacement: passo 3, imagem 1 %32 360fly 4K Lens Replacement: passo 3, imagem 2 %32
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Lens Replacement: passo 4, imagem 1 %32
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Lens Replacement: passo 5, imagem 1 %32 360fly 4K Lens Replacement: passo 5, imagem 2 %32
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Lens Replacement: passo 6, imagem 1 %32 360fly 4K Lens Replacement: passo 6, imagem 2 %32 360fly 4K Lens Replacement: passo 6, imagem 3 %32
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K Lens Replacement, SD Card: passo 7, imagem 1 %32
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K Lens Replacement: passo 8, imagem 1 %32
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K Lens Replacement: passo 9, imagem 1 %32
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K Lens Replacement: passo 10, imagem 1 %32
    • Press and release the SD card to remove it from the circuit assembly.
  11. 360fly 4K Lens Replacement, Lens: passo 11, imagem 1 %32
    • Unscrew the five 3mm screws with a T4 screwdriver.
  12. 360fly 4K Lens Replacement: passo 12, imagem 1 %32
    • Gently push against the lens module to remove it from the 360fly 4K assembly.
Conclusão
Jacob Herron
Membro desde: 11/08/17
463 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G3, Baechle Fall 2017 Membro de IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
Membros da 3
Autoria de 3 guias
4 comentários
Hi. Where to get a replacement lens as I am in need for this repair, but 360fly offer a full service for $150 and do not sell spare lenses. Thx
anguel nakov - Responder
There is no info where to buy the replacement lens.
gelo3000 - Responder
Anyone know about usb pinout? I lost my charger adapter
Nuri Can PEHLİVAN - Responder
Hi.
I inadvertently found your question.
I have this same problem.
I've lost the charger, too, and now I'm looking for a chance to charge without a base, or a chance to buy a base.
Imants
Imants R -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,605
