Ir para o conteúdo principal
360fly 4K Battery Replacement
O que você precisa
  1. 360fly 4K Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
    In the older model for Fly360 camera, the screws are PH000.
    Renjamin - Responder
    In the old 360Fly HD camera, the screw requires a #00 Philips head screwdriver. Unfortunately for me, one of the screws on mine was torqued down a bit too tight, that I ended up stripping the screw head trying to loosen it by hand.
    XzTS - Responder
  3. 360fly 4K Battery Replacement: passo 3, imagem 1 %32 360fly 4K Battery Replacement: passo 3, imagem 2 %32
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Battery Replacement: passo 4, imagem 1 %32
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Battery Replacement: passo 5, imagem 1 %32 360fly 4K Battery Replacement: passo 5, imagem 2 %32
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Battery Replacement: passo 6, imagem 1 %32 360fly 4K Battery Replacement: passo 6, imagem 2 %32 360fly 4K Battery Replacement: passo 6, imagem 3 %32
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Do I have to remove the battery to replace the SD card?
    BoB - Responder
Conclusão
Jacob Herron
Membro desde: 11/08/17
463 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G3, Baechle Fall 2017 Membro de IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
Membros da 3
Autoria de 3 guias
4 comentários
Wich one battery Can I use to replace It?
Marco Pereira - Responder
Where can i purchase a battery
john hernandez - Responder
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 2,448
