Ir para o conteúdo principal
2023 Honda Civic Side Mirror Replacement
O que você precisa
  1. 2023 Honda Civic Side Mirror Replacement, Side Mirror: passo 1, imagem 1 %32
    • Use a plastic pry bar to gently open the door interior panel.
    • Avoid excessive force to prevent damage or scratches.
  2. 2023 Honda Civic Side Mirror Replacement: passo 2, imagem 1 %32
    • Use a flat-head screwdriver to remove the screws securing the door, then disconnect the rearview mirror and side mirror control button.
  3. 2023 Honda Civic Side Mirror Replacement: passo 3, imagem 1 %32
    • Pull the bottom of the door interior panel with your hands to disengage it from the fixing clips.
  4. 2023 Honda Civic Side Mirror Replacement: passo 4, imagem 1 %32 2023 Honda Civic Side Mirror Replacement: passo 4, imagem 2 %32
    • Tear a small gap in the sound insulation cotton by hand.
    • Find the interface between the side mirror and the power supply in the car, then disconnect it.
  5. 2023 Honda Civic Side Mirror Replacement: passo 5, imagem 1 %32 2023 Honda Civic Side Mirror Replacement: passo 5, imagem 2 %32
    • Using a hex wrench screwdriver, firmly loosen the screws holding the side view mirror inside the door.
    • Remove the side mirror.
    • Be careful not to let the mirror move into the door gap after loosening the screw.
  6. 2023 Honda Civic Side Mirror Replacement: passo 6, imagem 1 %32 2023 Honda Civic Side Mirror Replacement: passo 6, imagem 2 %32
    • Install the new side mirror and reattach the screws.
  7. 2023 Honda Civic Side Mirror Replacement: passo 7, imagem 1 %32 2023 Honda Civic Side Mirror Replacement: passo 7, imagem 2 %32
    • Connect the new side-view mirror to the power supply and control bar, and then reinstall the door panel.
  8. 2023 Honda Civic Side Mirror Replacement: passo 8, imagem 1 %32 2023 Honda Civic Side Mirror Replacement: passo 8, imagem 2 %32
    • Test the side mirror control buttons to ensure they work and the mirrors move left and right.
    • Check the dashboard for errors. If everything works, the task is successfully completed.
    • Blind spot monitoring and other features require on-road testing.
Linha de Chegada
yifan shi
Membro desde: 09/19/23
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 39
Duração total: 372
