Ir para o conteúdo principal
2021 Kia Rio Driver Side Fuse Replacement
O que você precisa
  1. 2021 Kia Rio Driver Side Fuse Replacement, 2021 Kia Rio Driver Side Fuse: passo 1, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement, 2021 Kia Rio Driver Side Fuse: passo 1, imagem 2 %32
    • Lift the bar under the car seat and push back the seat to make the fuse box easier to access.
  2. 2021 Kia Rio Driver Side Fuse Replacement: passo 2, imagem 1 %32
    • Assure that the vehicle is completely off, you can tell that this is the case if the small light above the words on the button is off, and the engine should be silent.
  3. 2021 Kia Rio Driver Side Fuse Replacement: passo 3, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 3, imagem 2 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 3, imagem 3 %32
    • Grip the handle on the bottom side of the fuse box cover and pull it up and away to remove the cover.
  4. 2021 Kia Rio Driver Side Fuse Replacement: passo 4, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 4, imagem 2 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 4, imagem 3 %32
    • Locate the desired fuse using the owners manual, on page 7:63.
    • The diagram to locate fuses is also on the backside of the fuse box cover.
  5. 2021 Kia Rio Driver Side Fuse Replacement: passo 5, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 5, imagem 2 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 5, imagem 3 %32
    • Use the fuse puller or pliers to remove the fuse by gripping the long sides of the fuse and gently pulling the fuse directly out towards you.
    • The vehicle provides you with a fuse puller in the cover for the engine compartment fuse box.
  6. 2021 Kia Rio Driver Side Fuse Replacement: passo 6, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 6, imagem 2 %32
    • Align the holes located on the top of the fuse with the prongs on the fuse tester.
    • Press the prongs into the holes gently, making sure the prongs make contact with the metal at the bottom of the holes.
    • If the light glows green, the fuse is in working condition, if not, move forward with this guide.
    • If the light does glow, the fuse is likely not the cause of the issue you are having, you may be better off trying a different solution.
  7. 2021 Kia Rio Driver Side Fuse Replacement: passo 7, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 7, imagem 2 %32
    • Retrieve a new fuse of the same rating, it should have the same series of letters and numbers on it as the one you are replacing (e.g. 20A, 10A, etc.).
    • The vehicle often comes with spare fuses in the cover of the engine compartment fuse panel, as pictured.
  8. 2021 Kia Rio Driver Side Fuse Replacement: passo 8, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 8, imagem 2 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 8, imagem 3 %32
    • Align the new fuse straight into the open slot gripping the fuse with the fuse puller in a similar manner to step 5.
    • Gently push the fuse into the slot left by the fuse that was removed, there should be relatively minimal resistance when pushing it in.
    • Use your finger to apply moderate pressure until the top of the fuse aligns with the other fuses.
  9. 2021 Kia Rio Driver Side Fuse Replacement: passo 9, imagem 1 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 9, imagem 2 %32 2021 Kia Rio Driver Side Fuse Replacement: passo 9, imagem 3 %32
    • Orient the fuse box cover to its previous position, with the handle facing downward, and insert the top end of the cover into position.
    • Press the cover in and back into place, it should be flush with its surroundings.
Conclusão
To check if this guide worked, simply turn on the vehicle and test the previously unresponsive function, it should be completely restored!
Uma outra pessoa concluiu este guia.
Derek Segers
Membro desde: 04/15/24
169 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-4, Morris Spring 2024 Membro de UC Davis, Team 1-4, Morris Spring 2024
UCD-MORRIS-S24S1G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 40
Duração total: 97
