Ir para o conteúdo principal
2021 Chevrolet Silverado Tail Light Replacement
O que você precisa
  1. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, imagem 3 %32
    • Open the tailgate.
    • Remove the top and bottom T15 screws from each side of the tail lights.
    • Gently remove the tail lights by pulling outward.
  2. 2021 Chevrolet Silverado Tail Light Replacement: passo 2, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 2, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 2, imagem 3 %32
    • Unplug the sockets and remove the reverse light bulb from the tail light.
  3. 2021 Chevrolet Silverado Tail Light Replacement: passo 3, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 3, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 3, imagem 3 %32
    • Plug the brake lights connector.
    • Twist and secure the socket tightly.
    • Plug in the turn signal bulb connector. Twist and secure tightly.
  4. 2021 Chevrolet Silverado Tail Light Replacement: passo 4, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 4, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 4, imagem 3 %32
    • Plug in the parking lights connector. Twist and secure the socket tightly.
    • Plug in the TURN SIGNALS connector. Please follow the same steps for the other side of the tail lights.
    • Make sure all the connections are plugged and tight. Also ensure that the caps are sealed.
  5. 2021 Chevrolet Silverado Tail Light Replacement: passo 5, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 5, imagem 2 %32
    • First, remove the reverse light bulb from the vehicle.
    • Then, connect the socket to the reverse light connector from the new tail light.
  6. 2021 Chevrolet Silverado Tail Light Replacement: passo 6, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 6, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 6, imagem 3 %32
    • Lastly, plug the vehicle’s tail light socket to new tail light connector.
  7. 2021 Chevrolet Silverado Tail Light Replacement: passo 7, imagem 1 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 7, imagem 2 %32 2021 Chevrolet Silverado Tail Light Replacement: passo 7, imagem 3 %32
    • Gently push the tail light into the mounting position and use T15 screwdriver to tighten the top and bottom screws.
    • Repeat the same process for the other side of the tail light.
Conclusão
Uma outra pessoa concluiu este guia.
Adrian
Membro desde: 06/27/23
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 146
Duração total: 1,495
