Ir para o conteúdo principal
2020 Honda Civic Cabin Filter Replacement
O que você precisa
  1. 2020 Honda Civic Cabin Filter Replacement, Cabin Filter: passo 1, imagem 1 %32 2020 Honda Civic Cabin Filter Replacement, Cabin Filter: passo 1, imagem 2 %32 2020 Honda Civic Cabin Filter Replacement, Cabin Filter: passo 1, imagem 3 %32
    • Locate the Cabin in the passenger side of the car.
  2. 2020 Honda Civic Cabin Filter Replacement: passo 2, imagem 1 %32 2020 Honda Civic Cabin Filter Replacement: passo 2, imagem 2 %32 2020 Honda Civic Cabin Filter Replacement: passo 2, imagem 3 %32
    • Locate the two pins holding the cabin in place.
    • Apply pressure on both sides and pull down.
  3. 2020 Honda Civic Cabin Filter Replacement: passo 3, imagem 1 %32 2020 Honda Civic Cabin Filter Replacement: passo 3, imagem 2 %32
    • Locate two pins on both sides of air filter cabin.
    • Push inwards and pull to take out. (usually only one is enough to take the entire thing out)
  4. 2020 Honda Civic Cabin Filter Replacement: passo 4, imagem 1 %32
    • Locate the air filter.
    • It should either be empty or have a used one inside.
  5. 2020 Honda Civic Cabin Filter Replacement: passo 5, imagem 1 %32 2020 Honda Civic Cabin Filter Replacement: passo 5, imagem 2 %32
    • Take out filter and replace with brand new one.
Conclusão
As each image shows concise and enough information to change your cabin air filter. Each commuter will be provided with clean and pure air to the cabin.
Sean Colindres
Membro desde: 10/22/23
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 107
Duração total: 475
