Ir para o conteúdo principal
2019 Nissan Sentra Keyless Remote Battery
O que você precisa
  1. 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 3 %32
    • Remove the key by pulling the lever on the back of the keyless remote.
  2. 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 3 %32
    • Use a prying tool to pry the back cover away from the rest of the remote.
  3. 2019 Nissan Sentra Keyless Remote Battery: passo 3, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 3, imagem 2 %32
    • Use your fingers to remove the old battery from the remote.
  4. 2019 Nissan Sentra Keyless Remote Battery: passo 4, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 4, imagem 2 %32
    • Be sure to verify your new battery matches your old battery.
    • Place the new battery in the remote and firmly press down to make sure it’s secure.
  5. 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 3 %32
    • Place the back of the remote back onto the remote.
  6. 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 3 %32
    • Once the back is firmly secured on the key remote, place the key back into the remote.
    • Be sure to dispose of the old battery.
  7. 2019 Nissan Sentra Keyless Remote Battery: passo 7, imagem 1 %32
    • Make sure to test the key remote to make sure it is working properly.
Linha de Chegada
Sidney
Membro desde: 02/17/21
193 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 54
Últimos 30 dias: 303
Duração total: 8,088
