Ir para o conteúdo principal
2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement
O que você precisa
  1. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: passo 1, imagem 1 %32 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement, Battery: passo 1, imagem 2 %32
    • Press the button or slide the groove to release the emergency key.
  2. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 2, imagem 1 %32 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 2, imagem 2 %32
    • After removing the key blade, locate the slot or indentation.
    • Insert a flathead into the slot and gently twist to open the key fob.
  3. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 3, imagem 1 %32 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 3, imagem 2 %32
    • Carefully lift the cover to reveal the internal components.
  4. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 4, imagem 1 %32
    • Use a non-metallic tool or your hand to gently pry out the old battery.
    • Dispose of the old battery following local regulations.
  5. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 5, imagem 1 %32
    • Place the new battery into the designated slot with the correct polarity.
    • Ensure the battery is securely in place.
  6. 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 6, imagem 1 %32 2019 Hyundai Kona and Santa Fe Key Fob Battery Replacement: passo 6, imagem 2 %32
    • Align the cover with the key fob and press down to snap it into place.
    • Ensure the key fob is securely closed.
    • Slide the key blade back into its slot until it clicks into place.
    • Press any button on the key fob to verify that the new battery is functioning.
    • If the light blinks on the front of the fob key, the battery replacement is successful.
Conclusão
sepi
Membro desde: 09/13/23
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 33
Últimos 30 dias: 137
Duração total: 531
