Introdução
Replacing the Cabin Air Filter may sound like it's complicated. It is far from hard. It doesn't require any tools. It also, only takes about 5 minutes to complete. I spent about $24 dollars at the O'Reilly's for the Filter. This sounds like a deal to me, no labor chargers either. You should change your filter every 15,000 to 30,000 miles. You don't want to cause motor burn up. This is a step-by-step guide on how to change the Cabin Air Filter for a Toyota Corolla 2018.
Open Glove compartment located on the passenger side of the vehicle.
Pull the plastic lever to the right to detach from glove compartment hook.
Uma outra pessoa concluiu este guia.
