Ir para o conteúdo principal
2018 Nissan Murano Key Fob Battery Replacement
O que você precisa
  1. 2018 Nissan Murano Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32 2018 Nissan Murano Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 3 %32
    • Pull the button on the back of the key fob from right to left while pulling the hoop on the top.
    • Completely remove the key from the fob.
  2. 2018 Nissan Murano Key Fob Battery Replacement: passo 2, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 2, imagem 2 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 2, imagem 3 %32
    • Point the fob vertically towards you and find the groove between the front and the back.
    • Carefully, using an iFixit opening tool or similar household object, pry open the fob by sliding the flat end into the groove.
    • Slide your opening tool around the entire fob following the groove.
    • Pull apart the two main pieces.
  3. 2018 Nissan Murano Key Fob Battery Replacement: passo 3, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 3, imagem 2 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Carefully remove the individual pieces from the inside one at a time.
    • There are two pieces in total to remove.
  4. 2018 Nissan Murano Key Fob Battery Replacement: passo 4, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 4, imagem 2 %32
    • Place the new battery into the key in the same orientation as the one that was removed.
    • You will notice on the battery that there are small letters. When placing the battery in the fob those letters need to face up.
  5. 2018 Nissan Murano Key Fob Battery Replacement: passo 5, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 5, imagem 2 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 5, imagem 3 %32
    • Set the pieces back within the fob.
    • Gently line up the pieces and press them together to close it.
  6. 2018 Nissan Murano Key Fob Battery Replacement: passo 6, imagem 1 %32 2018 Nissan Murano Key Fob Battery Replacement: passo 6, imagem 2 %32
    • Add the physical key back into the fob.
    • Slide the key back into position and push down until you feel a small click. When you hear the small click you know the key is properly in.
Linha de Chegada
Sydney Cooper
Membro desde: 02/15/21
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 25
Últimos 30 dias: 78
Ao todo: 5,706
