Ir para o conteúdo principal
2017 Toyota Corolla Engine Air Filter Replacement
O que você precisa
  1. 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 2 %32 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: passo 1, imagem 3 %32
    • Caution: Ensure that the vehicle is off for at least two minutes and is parked before working.
    • Pop the hood and locate the engine's air filter. It is the object circled in red.
  2. 2017 Toyota Corolla Engine Air Filter Replacement: passo 2, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 2, imagem 2 %32
    • To unclip the air filter cover, you must first take off this tube, connected to the top.
  3. 2017 Toyota Corolla Engine Air Filter Replacement: passo 3, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 3, imagem 2 %32
    • Undo the hinges at each side of the cover.
    • Put a little bit of pressure down and they should unclip easily.
  4. 2017 Toyota Corolla Engine Air Filter Replacement: passo 4, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 4, imagem 2 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 4, imagem 3 %32
    • Shift the cover forward and it should come off. Have two hands on it, one at the front and the back to jimmy it out easier.
    • Do not worry about holding onto it after taking it off.
  5. 2017 Toyota Corolla Engine Air Filter Replacement: passo 5, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 5, imagem 2 %32
    • Keep the cover up enough to slide the air filter right out of the cover box.
  6. 2017 Toyota Corolla Engine Air Filter Replacement: passo 6, imagem 1 %32 2017 Toyota Corolla Engine Air Filter Replacement: passo 6, imagem 2 %32
    • Insert the engine air filter you've acquired into the previous air filter's slot. It should fit like a glove once slotted properly.
    • Ensure that the marked sides align properly, or else it won't fit no matter which way you put it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 70
Duração total: 275
