Ir para o conteúdo principal
2017 Kia Niro Headlight Replacement
O que você precisa
  1. 2017 Kia Niro Headlight Replacement, Headlight: passo 1, imagem 1 %32
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: passo 2, imagem 1 %32
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: passo 3, imagem 1 %32
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: passo 4, imagem 1 %32
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: passo 5, imagem 1 %32
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: passo 6, imagem 1 %32
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: passo 7, imagem 1 %32
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: passo 8, imagem 1 %32
    • Reattach the cap you previously set aside by rotating clockwise until secure.
Linha de Chegada
3 outras pessoas executaram este guia.
Sydney Harper
Membro desde: 10/23/20
229 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S9-G6, Cowan Fall 2020 Membro de Texas Tech, Team S9-G6, Cowan Fall 2020
TTU-COWAN-F20S9G6
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 96
Duração total: 3,923
