Ir para o conteúdo principal
2017 Honda Civic Sport Brake Light Bulb Replacement
O que você precisa
  1. 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 2 %32 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: passo 1, imagem 3 %32
    • Turn your vehicle off before beginning.
    • Open your trunk.
    • Use a Phillips #2 screwdriver to remove the two screws securing the shield.
  2. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 2, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 2, imagem 2 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 2, imagem 3 %32
    • To remove the brake light housing, start from the top of the frame and pull the shield outwards.
  3. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 3, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 3, imagem 2 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 3, imagem 3 %32
    • Twist the brake light socket counterclockwise and pull it directly out, with care not to damage the wires.
    • The brake light has a gray plug.
  4. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 4, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 4, imagem 2 %32
    • Grip light bulb and slide it directly out of its socket.
  5. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 5, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 5, imagem 2 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 5, imagem 3 %32
    • Install a new bulb by pressing it into the socket.
    • You'll hear a "click" when it's properly inserted.
  6. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 6, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 6, imagem 2 %32
    • Place the socket back in its housing and twist it clockwise.
  7. 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 7, imagem 1 %32 2017 Honda Civic Sport Brake Light Bulb Replacement: passo 7, imagem 2 %32
    • Align the brake light shield with the two sockets and firmly press the brake light inward.
    • You'll hear a "pop" when the shield is secured.
Conclusão
Enjoy your functional brake light!
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 39
Últimos 30 dias: 196
Duração total: 4,174
