Ir para o conteúdo principal
2017 Honda Accord Headlight Replacement
O que você precisa
  1. 2017 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 1 %32 2017 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 2 %32 2017 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 3 %32
    • Pull the Hood Latch lever inside the car, located under the steering wheel.
    • Lift the hood while pressing up on the lever under the front of the hood.
  2. 2017 Honda Accord Headlight Replacement: passo 2, imagem 1 %32 2017 Honda Accord Headlight Replacement: passo 2, imagem 2 %32
    • Lift up the hood prop rod and insert it into the hole on the underside of the hood.
  3. 2017 Honda Accord Headlight Replacement: passo 3, imagem 1 %32 2017 Honda Accord Headlight Replacement: passo 3, imagem 2 %32
    • Use a 1/4" ratcheting wrench and a 10mm socket to loosen the bolt on the negative terminal head.
    • Lift the terminal up off of the battery and place it to the side.
  4. 2017 Honda Accord Headlight Replacement: passo 4, imagem 1 %32
    • Use the clip remover tool to pry the clip up to remove it.
  5. 2017 Honda Accord Headlight Replacement: passo 5, imagem 1 %32 2017 Honda Accord Headlight Replacement: passo 5, imagem 2 %32 2017 Honda Accord Headlight Replacement: passo 5, imagem 3 %32
    • Use a 1/4" ratcheting wrench and a 10mm socket to remove the three bolts.
  6. 2017 Honda Accord Headlight Replacement: passo 6, imagem 1 %32
    • Use a 1/4" ratcheting wrench, a 6" extension and a 10mm socket to remove the last bolt.
  7. 2017 Honda Accord Headlight Replacement: passo 7, imagem 1 %32 2017 Honda Accord Headlight Replacement: passo 7, imagem 2 %32
    • Gently pull the headlight out.
  8. 2017 Honda Accord Headlight Replacement: passo 8, imagem 1 %32 2017 Honda Accord Headlight Replacement: passo 8, imagem 2 %32
    • Press the tab on the connector and pull. Do this for all 4 connectors.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 85
Duração total: 3,370
