Ir para o conteúdo principal
2017 Honda Accord Cabin Air Filter Replacement
O que você precisa
  1. 2017 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 3 %32
    • Push the lever connected to the right side of the glove box.
    • Remove items in the glove box as they can be unsafe moving forward.
  2. 2017 Honda Accord Cabin Air Filter Replacement: passo 2, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 2, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 2, imagem 3 %32
    • Push inwards on both sides of the glove box to release it.
    • Ensure the glove box does not hang from the hinges.
  3. 2017 Honda Accord Cabin Air Filter Replacement: passo 3, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 3, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 3, imagem 3 %32
    • Push the left and right hinges to release the cabin filter cover.
  4. 2017 Honda Accord Cabin Air Filter Replacement: passo 4, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 4, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 4, imagem 3 %32
    • Carefully remove the cover and pull the old cabin filter from the holder.
    • Note the direction of the air flow (downwards).
  5. 2017 Honda Accord Cabin Air Filter Replacement: passo 5, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 5, imagem 2 %32
    • Insert the new cabin filter with the direction indicated from the previous filter (downwards).
  6. 2017 Honda Accord Cabin Air Filter Replacement: passo 6, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 6, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 6, imagem 3 %32
    • Place the filter cover and ensure both hinges click into the holder.
  7. 2017 Honda Accord Cabin Air Filter Replacement: passo 7, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 7, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 7, imagem 3 %32
    • Insert the glovebox back into the dashboard and lock the tabs into place.
  8. 2017 Honda Accord Cabin Air Filter Replacement: passo 8, imagem 1 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 8, imagem 2 %32 2017 Honda Accord Cabin Air Filter Replacement: passo 8, imagem 3 %32
    • Pull the lever back onto the glove box hinge.
Conclusão
Pamvir Duhar
Membro desde: 09/19/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 120
Duração total: 5,141
