Ir para o conteúdo principal
2017-2022 Honda CR-V Reverse Light Bulb Replacement
O que você precisa
  1. 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: passo 1, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: passo 1, imagem 2 %32
    • Open the trunk.
  2. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 2, imagem 1 %32
    • Determine which bulb(s) needs to be replaced.
  3. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 3, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 3, imagem 2 %32
    • Open the panel with a flathead screwdriver.
    • If you do not have a flathead screwdriver, anything with a flat surface should work.
  4. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 4, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 4, imagem 2 %32
    • Hold down tab and remove the cable.
  5. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 5, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 5, imagem 2 %32
    • Turn the plug to the left until you hear a click.
  6. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 6, imagem 1 %32
    • Pull the socket out of its housing.
  7. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 7, imagem 1 %32
    • Take the bulb out the socket.
  8. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 8, imagem 1 %32
    • Replace the bulb.
    • Make sure you use the Hella 921TB Bulb 921 12V 16W W2.1X9.5D T5.
  9. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 9, imagem 1 %32
    • Put the plug back into its original position.
  10. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 10, imagem 1 %32
    • Turn plug to the right until secure.
  11. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 11, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 11, imagem 2 %32
    • Reinsert the cable.
  12. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 12, imagem 1 %32 2017-2022 Honda CR-V Reverse Light Bulb Replacement: passo 12, imagem 2 %32
    • Reinsert the panel.
Conclusão
This guide tells you how to replace the bulb, and how to put everything back together
Uma outra pessoa concluiu este guia.
Hashmat Jadoon
Membro desde: 09/17/23
235 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 64
Duração total: 253
