Introdução
In this guide you will learn how to replace a low beam headlight bulb for the 10th generation 2016-2021 Honda Civic.
Before beginning the repair, turn off your engine and put on your emergency break.
O que você precisa
Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
3 outras pessoas executaram este guia.
2 comentários
Hi @annasmith55441, the link to the bulb listed at the top of the guide under parts is the correct type for a 2016-2021 Honda Civic. There are a couple of links to choose from depending on the features you need from the bulb. If you're concerned that these bulbs won't work for your car, Amazon has a feature to check the compatibility of the bulbs with your specific car make and model at the top of bulb page link. I hope this helps!
