Ir para o conteúdo principal
2015 Mini Cooper Key Fob Battery Replacement
O que você precisa
  1. 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32
    • Using a plastic opening tool, create leverage in the corner of the backplate.
    • Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
    • Repeat on the other side.
  2. 2015 Mini Cooper Key Fob Battery Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening tool in the notch on the front of the key fob and pry up the backplate in the center until it pops off.
    • If you hear cracking, make sure both the corners are detached.
  3. 2015 Mini Cooper Key Fob Battery Replacement: passo 3, imagem 1 %32 2015 Mini Cooper Key Fob Battery Replacement: passo 3, imagem 2 %32
    • Press the silver button on the side of the neck, and pull the key out.
    • Insert the key into the latch on the back of the battery casing, above the slot where it comes out. Pull up and out.
    • If the backing doesn't come out easily, take the key out and try again.
  4. 2015 Mini Cooper Key Fob Battery Replacement: passo 4, imagem 1 %32
    • Use your finger to press down and forward on the battery. It should pop out.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 42
Últimos 30 dias: 131
Duração total: 6,914
