Introdução
This guide details the process of removing and replacing the tail lights for a 2015-2019 Dodge Charger.
The tail lights are a major safety aspect to vehicles. To ensure everyone’s safety on public roads, it is the driver’s responsibility to replace the tail lights when malfunctioning or worn out.
If your 2015-2019 Dodge Charger tail lights are in need of a replacement due to damage or aesthetic purposes, this guide will provide you with all the necessary steps to replace your taillights with ease.
NOTE: Perform the procedures after the vehicle has been turned off for at least 30 minutes. Make sure to turn off the ignition and engage the parking brake before you begin.
O que você precisa
Remove the rear plastic panel cover located inside the trunk by pushing the panel towards the center of the car.
Repeat the same steps to replace the other tail light.
Uma outra pessoa concluiu este guia.
