Ir para o conteúdo principal
2015-2021 Volkswagen GTI Cabin Air Filter Replacement
O que você precisa
  1. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 3 %32
    • Open Glove Compartment.
    • Locate the two tabs on the corners of the glove compartment.
    • Push up on both tabs. One at a time or simultaneously.
    • Drop down the glove compartment.
  2. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 2, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 2, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 2, imagem 3 %32
    • After dropping down the glove compartment, locate the honeycomb compartment.
    • Behind the compartment is the old cabin air filter.
    • Located on the compartment are three clips. The clips are on the top section of the compartment.
    • To unlatch the three clips, apply pressure onto a flap on the right side while carefully unhooking each clip.
  3. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 3, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 3, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 3, imagem 3 %32
    • After removing the honeycomb compartment, set it aside.
    • Remove the old cabin air filter and throw it out.
    • If the filter does not slide out immediately, try pinching on the filter and pulling it out.
  4. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 4, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 4, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 4, imagem 3 %32
    • When installing the new air filter, notice the direction of the arrows on your old one.
    • Make sure to have the air flow arrows facing the same way (down). Push into the empty compartment.
  5. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 5, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 5, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 5, imagem 3 %32
    • Now we put the honeycomb compartment back.
    • Make sure to insert the lower tab into the slot.
    • It will stay ajar, to seal the compartment, simply apply pressure on the compartment.
    • It will click into place, but to be sure press along the edges.
  6. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 6, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 6, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 6, imagem 3 %32
    • Putting the glove compartment back.
    • Follow these steps to follow in order.
    • First, push up on the glove compartment until it clicks.
    • Second, make sure the brake element is assembled; the stick goes into the circular module.
    • Finally, push the glove compartment until you hear the second click.
  7. 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 7, imagem 1 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 7, imagem 2 %32 2015-2021 Volkswagen GTI Cabin Air Filter Replacement: passo 7, imagem 3 %32
    • After hearing the second click, the glove compartment should remain open.
    • Finally, you can close the glove compartment.
Conclusão
Uma outra pessoa concluiu este guia.
Hector C.
Membro desde: 03/20/24
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 51
Últimos 30 dias: 159
Duração total: 1,489
