Introdução
If the brake light or turn signal of your 2015-2023 sixth-generation Ford Mustang (S550) isn't working, follow this guide to replace the taillight assembly. While working on your car may seem daunting, this guide will highlight every step in replacing the taillight assembly of your 2015-2023 Ford Mustang.
Tips and Warnings
To prevent damaging your car, remember these warnings while replacing your taillight assembly:
- Do not cross-thread the 10 mm hex nuts and plastic knobs.
- Do not over-torque the 10 mm hex nuts and plastic knobs.
O que você precisa
Locate the two knobs inside the car's trunk.
Unscrew both knobs using your hand.
To secure the taillight assembly and trim, follow steps 1 through 5 in reverse order
