Introdução
After many road trips and the use of air conditioning, the cabin air filter picks up a lot of dust and dirt and ultimately makes it unhealthy to breathe the air provided by a dirty air filter. The process of changing a cabin air filter in a 2014 Toyota Corolla Model L is very simple and does not require any tools or prior knowledge. It is suggested to replace the cabin air filter every 15k to 30k miles in normal driving conditions. Knowing the simple process of changing the cabin air filter can save you money and time from going to someplace else to get it changed. The only part you will need for this replacement would be a new cabin air filter. I used an STP Air Filter SA10190 which can be found in most auto parts stores.
O que você precisa
