Ir para o conteúdo principal
2014 Subaru Impreza Hatchback Brake light Replacement
O que você precisa
    1. 2014 Subaru Impreza Hatchback Brake light Replacement, Brake Light: passo 1, imagem 1 %32
      • Turn off car engine
      Pergunte ao FixBot
      Comentar
    2. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 2, imagem 1 %32
      • Open the trunk of the car.
      Pergunte ao FixBot
      Comentar
    3. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 3, imagem 1 %32
      • Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
      • Unscrewing them will allow you to take out the brake light.
      Pergunte ao FixBot
      Comentar
    4. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 4, imagem 1 %32 2014 Subaru Impreza Hatchback Brake light Replacement: passo 4, imagem 2 %32
      • Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
      Pergunte ao FixBot
      Comentar
    5. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 5, imagem 1 %32
      • Gently pull the rear light straight back.
      Pergunte ao FixBot
      Comentar
    6. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 6, imagem 1 %32
      • Upon opening the brake light, you should see three bulbs in total.
      • The brake light is the one on the bottom.
      Pergunte ao FixBot
      Comentar
    7. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 7, imagem 1 %32 2014 Subaru Impreza Hatchback Brake light Replacement: passo 7, imagem 2 %32
      • To remove the brake light, twist the light bulb socket counterclockwise.
      • The bulb should come out as shown in the second image.
      Pergunte ao FixBot
      Comentar
    8. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 8, imagem 1 %32
      • To remove the bulb, gently pull out the bulb from its connector.
      Pergunte ao FixBot
      Comentar
    9. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 9, imagem 1 %32
      • Gently insert the new bulb into the connector.
      • Carefully insert the bulb, as the bulb is made of glass it is susceptible to breaking and cutting you if a lot of force is used to insert it in the connector.
      Pergunte ao FixBot
      Comentar
    10. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 10, imagem 1 %32 2014 Subaru Impreza Hatchback Brake light Replacement: passo 10, imagem 2 %32
      • Reinsert the bulb back into its initial position.
      • Gently twist the bulb clockwise to further tighten the bulb.
      Pergunte ao FixBot
      Comentar
    11. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 11, imagem 1 %32
      • Gently push the rear light cover back into its initial place.
      Pergunte ao FixBot
      Comentar
    12. 2014 Subaru Impreza Hatchback Brake light Replacement: passo 12, imagem 1 %32 2014 Subaru Impreza Hatchback Brake light Replacement: passo 12, imagem 2 %32
      • Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Equipe
1Comentário do guia
When the hand break is not working, what do I need to do to fix it?
Pastor Alpha Kougbaka - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 50
Ao todo: 2,576
