Ir para o conteúdo principal
2014 Mercedes C230 Front Parking Light Replacement
O que você precisa
  1. 2014 Mercedes C230 Front Parking Light Replacement, Front Parking Light: passo 1, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement, Front Parking Light: passo 1, imagem 2 %32
    • Turn off the car lights.
  2. 2014 Mercedes C230 Front Parking Light Replacement: passo 2, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 2, imagem 2 %32
    • Open the car hood by pulling the red lever placed under the light switch.
  3. 2014 Mercedes C230 Front Parking Light Replacement: passo 3, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 3, imagem 2 %32
    • Pull the lever outside of your car and open the hood.
  4. 2014 Mercedes C230 Front Parking Light Replacement: passo 4, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 4, imagem 2 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 4, imagem 3 %32
    • Press the clamp on one side of the light cover and pull it open.
    • The light cover is located behind the car headlight.
  5. 2014 Mercedes C230 Front Parking Light Replacement: passo 5, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 5, imagem 2 %32
    • Pull the smaller lamp out. It has a grey wire attached to it.
  6. 2014 Mercedes C230 Front Parking Light Replacement: passo 6, imagem 1 %32 2014 Mercedes C230 Front Parking Light Replacement: passo 6, imagem 2 %32
    • Pull out the old light bulb and replace it with the new one.
  7. 2014 Mercedes C230 Front Parking Light Replacement: passo 7, imagem 1 %32
    • Check if the light is working.
  8. 2014 Mercedes C230 Front Parking Light Replacement: passo 8, imagem 1 %32
    • Put the light cover back in place.
Conclusão
Daniil Bendatii
Membro desde: 05/10/21
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Duração total: 1,386
