Ir para o conteúdo principal
2014 Honda CTX 700NA Oil and Oil Filter Replacement
O que você precisa
  1. 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, imagem 1 %32 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, imagem 2 %32
    • Open the oil reservoir cap, located on the right side of the bike just behind the foot peg.
  2. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 2, imagem 1 %32 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 2, imagem 2 %32 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 2, imagem 3 %32
    • Using a ratchet and socket, loosen the bolt.
  3. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 3, imagem 1 %32
    • Once the bolt is removed the oil will drain out. Let all of the oil drain into the oil pan.
    • The drip should be as pictured before screwing the bolt back in.
  4. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 4, imagem 1 %32
    • Once the bolt is tightly secured back in, unscrew the oil filter.
    • The oil filter is located on the underside of the bike but near the front wheel. If the filter is too tight, use channel lock pliers to get it off.
  5. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 5, imagem 1 %32 2014 Honda CTX 700NA Oil and Oil Filter Replacement: passo 5, imagem 2 %32
    • Once the new oil filter is installed, return to the oil reservoir mentioned in step 1. Insert a funnel and begin pouring in new oil, the type of oil required is SAE 10W-30.
    • If you change the oil filter 3.6 quarts will be needed. If you didn't replace the oil filter only 3.3 quarts will be needed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 82
Últimos 30 dias: 265
Duração total: 3,302
