Ir para o conteúdo principal
2014 Fiat 500L Rear Windshield Wiper Replacement
O que você precisa
  1. 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: passo 1, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: passo 1, imagem 2 %32
    • Gently lift the wiper off of the window to begin.
  2. 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 2, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 2, imagem 2 %32
    • Using your thumb, push the wiper away from you and out of place. You will hear it click when it is coming off.
  3. 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 3, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 3, imagem 2 %32
    • Position the new blade to where it aligns perfectly with the existing wiper arm.
    • There is an ident on the existing wiper arm that the new wiper will fit into.
  4. 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 4, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 4, imagem 2 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 4, imagem 3 %32
    • Place your thumbs on the top of the wiper and your other fingers on the under side of the wiper, to put the wiper into place.
    • You will hear it click when it is locked into place.
  5. 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 5, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 5, imagem 2 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 5, imagem 3 %32
    • Gently rest the wiper against the windshield.
  6. 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 6, imagem 1 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 6, imagem 2 %32 2014 Fiat 500L Rear Windshield Wiper Replacement: passo 6, imagem 3 %32
    • Test out the new wiper.
    • Turn your car on and switch your wiper on. The new blade will fall off of the wiper arm if it is not fully attached. If it is fully attached, the wiper will work successfully.
Linha de Chegada
3 outras pessoas executaram este guia.
Sierra Sparre
Membro desde: 10/30/18
214 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G4, Bender Fall 2018 Membro de UC Davis, Team S1-G4, Bender Fall 2018
UCD-BENDER-F18S1G4
Membros da 3
1 Guia de autoria
Um comentário
Thanks for this...all other videos were wrong. I needed the step by step pics.
Sandra Watkins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 2,022
