Ir para o conteúdo principal
2014 Chevy Cruze Taillight Bulb Replacement
O que você precisa
  1. 2014 Chevy Cruze Taillight Bulb Replacement, Taillight Bulb: passo 1, imagem 1 %32
    • Open the trunk of the car.
  2. 2014 Chevy Cruze Taillight Bulb Replacement: passo 2, imagem 1 %32
    • Remove the deck trim plug using needle nose pliers.
  3. 2014 Chevy Cruze Taillight Bulb Replacement: passo 3, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 3, imagem 2 %32
    • Pull back the trunk deck trim cover to uncover the taillight assembly.
  4. 2014 Chevy Cruze Taillight Bulb Replacement: passo 4, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 4, imagem 2 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 4, imagem 3 %32
    • Remove the grey plastic connector with a flathead screwdriver, gently sliding it off.
    • Unplug the taillight cable.
  5. 2014 Chevy Cruze Taillight Bulb Replacement: passo 5, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 5, imagem 2 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 5, imagem 3 %32
    • Open the two screw covers.
    • If the screw covers do not come open, use a flathead screwdriver to leverage them open.
  6. 2014 Chevy Cruze Taillight Bulb Replacement: passo 6, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 6, imagem 2 %32
    • Remove the two screws with a Phillips head screwdriver.
  7. 2014 Chevy Cruze Taillight Bulb Replacement: passo 7, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 7, imagem 2 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 7, imagem 3 %32
    • To remove the taillight assembly, first use a flathead screwdriver to pry the taillight up and slide a piece of twine beneath each side.
  8. 2014 Chevy Cruze Taillight Bulb Replacement: passo 8, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 8, imagem 2 %32
    • Once the twine is securely behind the taillight assembly, take hold of both pieces of twine and pull straight back to pop the assembly out.
  9. 2014 Chevy Cruze Taillight Bulb Replacement: passo 9, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 9, imagem 2 %32
    • Remove the bulb socket from the taillight assembly by turning it counterclockwise.
  10. 2014 Chevy Cruze Taillight Bulb Replacement: passo 10, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 10, imagem 2 %32
    • Remove the defective bulb.
    • If the bulb does not come free, use a flathead screwdriver to press against the plastic base of the bulb and leverage it out of the socket.
    • Do not press the screwdriver against the bulb itself. This may cause it to shatter.
    • Once the bulb has been removed, be sure to place it in a safe area where there is no risk of it breaking.
    • To dispose of the defective bulb, wrap it in a secondary layer of disposable packaging (such as paper towels within a plastic bag) before throwing it away.
    • Guidelines for disposing of halogen lightbulbs can vary. Be sure to double-check your local disposal guidelines before throwing the defective bulb away.
  11. 2014 Chevy Cruze Taillight Bulb Replacement: passo 11, imagem 1 %32 2014 Chevy Cruze Taillight Bulb Replacement: passo 11, imagem 2 %32
    • Push the new lightbulb into the socket.
    • Do not apply excessive force to the bulb.
    • Ensure that all the lights are working properly before driving the car.
Conclusão
McKenzie
Membro desde: 10/05/23
193 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 227
