Introdução
You may have a blown fuse in your 2014-2022 (3rd Gen) Mazda 6 if electrical systems like powered seats, power outlets, or speaker cease working properly.
This guide will show you how to identify and replace blown fuses in your 2014-2022 (3rd Gen) Mazda 6. This fix does not require special skills or tools, and is a fairly safe and simple process.
If, after following this guide, your problems are not fixed it is recommended that you take your car to a trusted mechanic for more a in-depth diagnosis.
O que você precisa
Pull the hood release, found on the left side of the driver's footwell, to unlatch the hood.
Replace the fuse cover by first hooking the snaps into place and pushing the rest of the cover into place.
Replace the fuse puller on the lid of the engine bay's fuse box.
Replace the lid of the fuse box by first hooking the loop of the lid onto the hook on the fuse box then pushing the lid closed.
Remove the stand from supporting the hood.
Place the stand in the holder to your right.
Drop the hood from about six inches above the engine bay in order to give it enough force to close the hatch.
Alternatively you can lower the hood gently until it touches the latch, then push the hood down until the hood sits flush.
If you have gone through these steps and your issue hasn't been fixed, a different guide may be necessary.
