Ir para o conteúdo principal
2014-Present Kia Soul Side Mirror Replacement
O que você precisa
  1. 2014-Present Kia Soul Side Mirror Replacement, Side Mirror: passo 1, imagem 1 %32 2014-Present Kia Soul Side Mirror Replacement, Side Mirror: passo 1, imagem 2 %32
    • Slide the prying tool behind the interior cover, along the edge next to the windshield.
    • Pry the plastic cover from the top until it pops out.
    • When the cover is loose, gently pull it off.
  2. 2014-Present Kia Soul Side Mirror Replacement: passo 2, imagem 1 %32 2014-Present Kia Soul Side Mirror Replacement: passo 2, imagem 2 %32 2014-Present Kia Soul Side Mirror Replacement: passo 2, imagem 3 %32
    • Squeeze the white tab and gently remove the electric cable connector.
    • When removing the electric cable connector, be careful not to pull the wires out.
  3. 2014-Present Kia Soul Side Mirror Replacement: passo 3, imagem 1 %32 2014-Present Kia Soul Side Mirror Replacement: passo 3, imagem 2 %32 2014-Present Kia Soul Side Mirror Replacement: passo 3, imagem 3 %32
    • Use a 10 mm socket wrench to remove the three 10 mm bolts holding the mirror to the window.
  4. 2014-Present Kia Soul Side Mirror Replacement: passo 4, imagem 1 %32 2014-Present Kia Soul Side Mirror Replacement: passo 4, imagem 2 %32 2014-Present Kia Soul Side Mirror Replacement: passo 4, imagem 3 %32
    • When working on this step, hold onto the side mirror to prevent it from falling. It may be helpful to have someone assist you during this step.
    • Use needle nose pliers to grip the grommet (plastic anchor around the screw) and guide it through the hole to detach the side mirror from the car.
    • Make sure to clamp all four sides of the grommet simultaneously to guide it through the opening. Do not turn or remove the screw during this process.
  5. 2014-Present Kia Soul Side Mirror Replacement: passo 5, imagem 1 %32 2014-Present Kia Soul Side Mirror Replacement: passo 5, imagem 2 %32
    • Remove the side mirror from the car.
    • It should come off in one piece.
    • Be careful to not drop the side mirror as the fragile glass could shatter.
  6. 2014-Present Kia Soul Side Mirror Replacement: passo 6, imagem 1 %32
    • Position the new side mirror in the same place where the damaged mirror was removed.
    • Make sure that the holes of the new side mirror line up with the holes in the door.
    • Ensure that the grommet for the new side mirror passes through the same opening from which the damaged side mirror grommet was removed from in Step 4.
Conclusão
Alex D
Membro desde: 02/01/24
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 332
