Ir para o conteúdo principal
2014-Present Kia Soul Brake Light Replacement
O que você precisa
  1. 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, imagem 2 %32 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, imagem 3 %32
    • Open the car trunk.
  2. 2014-Present Kia Soul Brake Light Replacement: passo 2, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the four 20.0 mm screws from the tail light assembly.
  3. 2014-Present Kia Soul Brake Light Replacement: passo 3, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement: passo 3, imagem 2 %32 2014-Present Kia Soul Brake Light Replacement: passo 3, imagem 3 %32
    • Pull the tail light assembly off.
    • Apply a counterclockwise motion on the tail light while you are pulling it off.
    • Do not use too much force to prevent cracking the plastic lens.
  4. 2014-Present Kia Soul Brake Light Replacement: passo 4, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement: passo 4, imagem 2 %32 2014-Present Kia Soul Brake Light Replacement: passo 4, imagem 3 %32
    • Turn the brake light socket 1/4 counterclockwise and pull it from the tail light assembly.
    • The brake light is located at the bottom of the tail light assembly.
  5. 2014-Present Kia Soul Brake Light Replacement: passo 5, imagem 1 %32
    • Press the light bulb down and turn it 1/4 counterclockwise.
  6. 2014-Present Kia Soul Brake Light Replacement: passo 6, imagem 1 %32
    • Pull the light bulb out of the socket.
  7. 2014-Present Kia Soul Brake Light Replacement: passo 7, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement: passo 7, imagem 2 %32 2014-Present Kia Soul Brake Light Replacement: passo 7, imagem 3 %32
    • Press the new light bulb down into the socket and turn it 1/4 clockwise direction.
    • Before performing this action make sure you properly place the light bulb into the socket.
  8. 2014-Present Kia Soul Brake Light Replacement: passo 8, imagem 1 %32 2014-Present Kia Soul Brake Light Replacement: passo 8, imagem 2 %32 2014-Present Kia Soul Brake Light Replacement: passo 8, imagem 3 %32
    • Follow the guide in reverse order to put the socket and the tail light assembly back.
    • Before you screw the tail light assembly back have someone press the brake paddle to see if the new light bulb turns on.
Conclusão
4 outras pessoas executaram este guia.
Jean Guerrier
Membro desde: 03/23/21
265 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 166
Duração total: 6,088
