Ir para o conteúdo principal
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: passo 1, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: passo 1, imagem 2 %32
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: passo 2, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 2, imagem 2 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 2, imagem 3 %32
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: passo 3, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 3, imagem 2 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 3, imagem 3 %32
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: passo 4, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 4, imagem 2 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 4, imagem 3 %32
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: passo 5, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 5, imagem 2 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 5, imagem 3 %32
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: passo 6, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 6, imagem 2 %32
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: passo 7, imagem 1 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 7, imagem 2 %32 2013 Lexus IS250 Front Dome Light Replacement: passo 7, imagem 3 %32
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: passo 8, imagem 1 %32
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Conclusão
Christian
Membro desde: 10/23/23
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 39
Duração total: 135
