Ir para o conteúdo principal
2013 Infiniti G37 Dual Air Intakes Replacement
O que você precisa
  1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: passo 1, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: passo 1, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: passo 1, imagem 3 %32
    • Pull the hood latch located inside the car under your remote holder.
    • Outside the car, find the lever under the actual hood, and squeeze and lift the hood.
    • Unscrew the mass airflow filter box from the frame with a Phillips #1 screwdriver.
  2. 2013 Infiniti G37 Dual Air Intakes Replacement: passo 2, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 2, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 2, imagem 3 %32
    • Loosen the five bolts in the engine cover so you can have more space to access the mass airflow tubes.
  3. 2013 Infiniti G37 Dual Air Intakes Replacement: passo 3, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 3, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 3, imagem 3 %32
    • Loosen the mass airflow sensor from the airflow tube and safely move it to a safe location out of the way.
    • Use vice grips to remove the clamp.
  4. 2013 Infiniti G37 Dual Air Intakes Replacement: passo 4, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 4, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 4, imagem 3 %32
    • Loosen the last clamp, located at the head of the airflow tube, and give a firm tug towards you to free the entire piece.
  5. 2013 Infiniti G37 Dual Air Intakes Replacement: passo 5, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 5, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 5, imagem 3 %32
    • Connect the mass airflow tube and tighten the clamps with a flathead screwdriver.
  6. 2013 Infiniti G37 Dual Air Intakes Replacement: passo 6, imagem 1 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 6, imagem 2 %32 2013 Infiniti G37 Dual Air Intakes Replacement: passo 6, imagem 3 %32
    • After all the clamps are tightened, place the mass airflow sensor into the tube and tighten with a Phillips #1 screwdriver.
Linha de Chegada
Cordell Bowens
Membro desde: 09/16/20
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 894
