Introdução
Driving with a burnt-out headlight at night can be dangerous and against local laws and regulations. If your 2013 Honda Civic has a burnt-out headlight, this guide will walk you through how to replace the bulb. When changing the bulb, make sure to be careful to not damage the bulb. Also make sure the vehicle is turn off when starting.
Changing the bulb in a Honda Civic is relatively simple and you’ll be back on the road again in no time!
This guide is applicable to all Honda Civics in the 9th generation, from 2012-2015.
O que você precisa
3 outras pessoas executaram este guia.
2 comentários
Used this guide to replace bulb in my 2013 Honda. Clear pictures and accurate wording made replacement understandable snd Easy!
UK built Civics are different from step 5. Rather than turn the unit anti clockwise there's one of those metal clips you need to unhook by pressing inwards and pushing slightly left (towards the radiator) to release the bulb. Be careful as the stupid clip easily falls out of its hinge slots and you have to do it all by feel and touch as there's no room to see what you're doing.
