Ir para o conteúdo principal
2013 Honda Civic Headlight Replacement
O que você precisa
  1. 2013 Honda Civic Headlight Replacement, Headlight: passo 1, imagem 1 %32 2013 Honda Civic Headlight Replacement, Headlight: passo 1, imagem 2 %32
    • Lift the latch to open the car hood.
  2. 2013 Honda Civic Headlight Replacement: passo 2, imagem 1 %32
    • Pry up the center of the fastener with a flat-head screwdriver.
  3. 2013 Honda Civic Headlight Replacement: passo 3, imagem 1 %32
    • Pop the rivet loose and remove it.
  4. 2013 Honda Civic Headlight Replacement: passo 4, imagem 1 %32
    • Remove the wiper fluid tube.
  5. 2013 Honda Civic Headlight Replacement: passo 5, imagem 1 %32
    • Locate the headlight internally.
    • Turn the headlight counter-clockwise to unlock it.
  6. 2013 Honda Civic Headlight Replacement: passo 6, imagem 1 %32
    • Press down on the latch to unlock the bulb from the connector.
    • Remove the burnt-out bulb.
    • Replace with the new bulb.
  7. 2013 Honda Civic Headlight Replacement: passo 7, imagem 1 %32
    • Turn clockwise to lock.
Linha de Chegada
3 outras pessoas executaram este guia.
2 comentários
Used this guide to replace bulb in my 2013 Honda. Clear pictures and accurate wording made replacement understandable snd Easy!
madscientistnbmt - Responder
UK built Civics are different from step 5. Rather than turn the unit anti clockwise there's one of those metal clips you need to unhook by pressing inwards and pushing slightly left (towards the radiator) to release the bulb. Be careful as the stupid clip easily falls out of its hinge slots and you have to do it all by feel and touch as there's no room to see what you're doing.
Stu Magoo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 41
Últimos 30 dias: 205
Duração total: 9,759
