Introdução
This guide will show you how to replace the brake light in a 2013 Honda Civic. This guide is only applicable to all the 9th generation Honda Civics between the years 2012-2015. Driving with a burned-out brake light can cause a vehicle to be rear-ended, leading to an accident if it is not replaced. This guide will provide steps on how to replace a burned-out light bulb. Ensure that the vehicle is shut off before engaging in the replacement.
Before beginning this repair, turn off the car, engage the parking brake, and disconnect the battery.
O que você precisa
Open the trunk by pulling the latch located on the floor of the driver’s side.
Uma outra pessoa concluiu este guia.
