Ir para o conteúdo principal
2013 Honda Accord Headlight Replacement
O que você precisa
  1. 2013 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 1 %32 2013 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 2 %32 2013 Honda Accord Headlight Replacement, Headlight: passo 1, imagem 3 %32
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: passo 2, imagem 1 %32 2013 Honda Accord Headlight Replacement: passo 2, imagem 2 %32
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: passo 3, imagem 1 %32 2013 Honda Accord Headlight Replacement: passo 3, imagem 2 %32
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: passo 4, imagem 1 %32 2013 Honda Accord Headlight Replacement: passo 4, imagem 2 %32
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: passo 5, imagem 1 %32 2013 Honda Accord Headlight Replacement: passo 5, imagem 2 %32 2013 Honda Accord Headlight Replacement: passo 5, imagem 3 %32
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
Conclusão
Uma outra pessoa concluiu este guia.
Tahsin
Membro desde: 09/19/22
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 46
Ao todo: 3,607
