Ir para o conteúdo principal
2013 GMC Terrain Headlight Bulb Replacement
O que você precisa
  1. 2013 GMC Terrain Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • Identify which headlight is out.
  2. 2013 GMC Terrain Headlight Bulb Replacement: passo 2, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 2, imagem 2 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Turn the wheels toward the opposite side of the broken headlight.
    • Go to the Front fender on the side with the broken headlight and find the cover on the fender liner.
  3. 2013 GMC Terrain Headlight Bulb Replacement: passo 3, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 3, imagem 2 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 3, imagem 3 %32
    • Use a T15 Torx screwdriver to remove the screw.
    • Turn the cover counterclockwise to remove it.
  4. 2013 GMC Terrain Headlight Bulb Replacement: passo 4, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 4, imagem 2 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 4, imagem 3 %32
    • Reach into the hole to find the round cap to the bulb.
    • Turn it counterclockwise to expose the socket holding the bulb.
  5. 2013 GMC Terrain Headlight Bulb Replacement: passo 5, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 5, imagem 2 %32
    • Twist the socket counterclockwise and pull it out to expose the bulb.
  6. 2013 GMC Terrain Headlight Bulb Replacement: passo 6, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 6, imagem 2 %32
    • Unclip the old bulb from the socket.
  7. 2013 GMC Terrain Headlight Bulb Replacement: passo 7, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 7, imagem 2 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 7, imagem 3 %32
    • Grab your new bulb.
    • Make sure not to touch the actual bulb because the oils from your skin can cause it to burn out.
    • Plug it back into the socket and twist it clockwise in the hole.
  8. 2013 GMC Terrain Headlight Bulb Replacement: passo 8, imagem 1 %32
    • Place the headlight cover back on and turn it clockwise to secure it.
  9. 2013 GMC Terrain Headlight Bulb Replacement: passo 9, imagem 1 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 9, imagem 2 %32 2013 GMC Terrain Headlight Bulb Replacement: passo 9, imagem 3 %32
    • Place the inner fender cover over the hole.
    • Twist the cover clockwise until it's tight
    • Screw in the Torx screw until it is tight.
  10. 2013 GMC Terrain Headlight Bulb Replacement: passo 10, imagem 1 %32
    • Finally, your headlights should both work.
Conclusão
Now your headlights should work perfectly.
Uma outra pessoa concluiu este guia.
Rafaj27
Membro desde: 10/23/24
205 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 22
Últimos 30 dias: 107
Ao todo: 744
